Ionia Fair (Michigan) pull 7/31
Bus Man
07-26-2004 02:10:41
I got a message from one of the promoters and he said that the weigh-in is at 7:00AM and the pull starts at 9:00AM. There will be two sleds so how they slit them up will be determined that day. 19" draw bar, 24" back from center of axle, 15.5x38" max tire size ( 18.4 for tires 33" and below), #2500 - #6500 classes, only "top" cut tires allowed. You can pull a maximun of two times in each speed class by jumping one weight range in each speed class. You can pull a maximum of 4 times. Speed?? They show two different speeds in the fair book 2.8 and 4.5 and they show 3 and 5. We'll find out the day of the pull. I will be away from my computer until Friday so if you have any questions please call 1-989-593-3110 or 1-989-637-4277
