V-8 Sm Block Chevy Class...!!
BushogPapa
08-02-2004 20:44:11
What do ya think of this new class..?? Looks like Great Fun...!! 410 Cu In limit and Iron heads.. 5,300 lb.. They Really Storm down the track...!!!
Ron..
Earl S.
08-04-2004 12:21:12
 Re: V-8 Sm Block Chevy Class...!! in reply to BushogPapa, 08-02-2004 20:44:11
Papa, Here in Illinois we have 2 sanction class of mini rod limited 1800lb and 1900lb. Classes .We pull under ITPA www.itpapulling.com. Iwould like to see 2500 lb. class at least they might be able to take advantage of all the HP they have.They can throw the dirt and make the dust fly. Earl
CASEPOWER
08-03-2004 05:23:28
They make a bunch of noise. They just don't pull like you would think they would. The reason I say that is that, I change the gears on one of the local clubs sled. It takes less to stop one then a super/div 4 or 5 tractor of the same weight. Just watch the box the next time you see them run. The torque just aint there.
BushogPapa
08-03-2004 13:15:48
 Re: V-8 Sm Block Chevy Class...!! in reply to CASEPOWER, 08-03-2004 05:23:28
None of these that I saw ran out of power...
They all had cut tires, and when the sled stopped them the tires were going so fast that they just "skated" sideways until the driver shut it down..!! I heard some estimate the HP at 600+.... I am sure they don't pull as much as the diesels, etc..But it was great fun watching these..!! Sure would be more fun than building a street rod...!!! AND a whole lot cheaper...!!
G-MAN
08-03-2004 13:39:35
 Re: V-8 Sm Block Chevy Class...!! in reply to BushogPapa, 08-03-2004 13:15:48
Every modified I've ever seen has had more power than they could put to the ground, but all their power is on the top end, which is probably what Casepower is referring to. To make 600+ horsepower in a naturally-aspirated small-block of only 410 cubic inches takes a big camshaft, huge ports and valves, single-plane intakes and other high-rpm parts - and high engine RPM - not much lugging ability there. They make a lot of noise and go fast, but I'm not sure they'd be more fun than a drag car, and are probably more dangerous. Although put that 600-horse SBC in a Nova or Chevelle, make it hook and you're going to cover a quarter mile quicker than those modifieds go 300 feet.
BushogPapa
08-04-2004 17:15:42
 Re: V-8 Sm Block Chevy Class...!! in reply to G-MAN, 08-03-2004 13:39:35
These guys were turning probably around 9,000 RPM, and had cut tires.. Funny to see a JD 3010 with a sm bk Chevy..!!
ChadS
08-04-2004 06:59:36
How about a pro farm antique class?? turbo,, 3000 rpm limit,, would be kinda like fantacy football,,,,, Chad
