What 5 bolt hubs fit IH C or H front spindle?
AC
08-03-2004 11:46:00
well, the title said it all, I have a B single front under my H, (someone made a plate to fit it) and I don't want it under there. I have a regulat front from a C, and I was wondering what hubs fit it so I can put pressed steel wheels under it. What about a regular H front end? What hubs fit that?...thanks, AC
colekicker
08-04-2004 21:27:26
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to AC, 08-03-2004 11:46:00
Pull your cast pieces off. Go to your local tractor dealer that deals in TISCO Parts. I just did a little bit of looking today at work and found that they have measurements of spindles in there book. Also, they have aftermarket hubs that are very reasonable, bearing kits to get the job done. Tomorrow night, I am doing some measuring and I am gonna get hubs on my super m. Oh, and I found it in the IH section. Probably have them for other models too.
Ohio H
08-03-2004 15:50:51
IH 300-350 Utility hubs fit the H spindle. Wheel bearings are the same. I have 15X4 Kubota six bolt wheels on them. Just had to oval out the bolt holes slightly.
ChadS
08-03-2004 12:26:32
MM Z front hubs fit the H front spindles, also, an old McCormick wagon running gear has hubs the fit the H, Best luck is to find a catalog that sells hubs and bearing kits, and match up the spindle length, size, etc etc. Just use some extra weight on the nose till you swap it, if it will be lite on the front,, chad
Don
08-03-2004 18:24:27
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to ChadS, 08-03-2004 12:26:32
How much weight will you lose i need to do that to my H im still a lil heavy
WILDMAN
08-04-2004 08:06:15
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to Don, 08-03-2004 18:24:27
2"PIPE WITH WELD ON HUBS CHEVY PATTERN LOOSE ABOUT 65LBS.
ChadS
08-04-2004 06:48:50
MM hubs are a bit heavier than most,, rough estimate,, 50-70 lbs loss. Chad
AC
08-04-2004 07:36:33
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to ChadS, 08-04-2004 06:48:50
See, I have a single front off of an f12 or a B, that someone re drilled and made a plate for. Therefore, knowing a C or B front end is lighter, I would like to find hubs that for that. I have seen a 230 in Hook with Weld draglights on it, so there must be something that fits it.....This single front if fine with me, but I think I want to put a bit of constant weight in the front so I don't have to change as much.....
ChadS
08-04-2004 07:40:27
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to AC, 08-04-2004 07:36:33
Run it see what you can do,, will be lite on our sled,, so come prepared. How lite can u get? Chad
Don
08-04-2004 09:36:21
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to ChadS, 08-04-2004 07:40:27
Chad are you goin to wauseon in november??
ChadS
08-04-2004 09:56:17
 Re: What 5 bolt hubs fit IH C or H front spindle? in reply to Don, 08-04-2004 09:36:21
No. Going to princeton IN if all goes well. ChadS
