Stroking a JD 2-cylinder
720Deere
08-04-2004 10:26:59
This seems to be a hot topic the last few days. Here's the dumb question of the day. Has anybody experimented with stroking the 2 cyl. diesels? I guess the ultimate answer is that Deere themselves did as the 80/820/830 is the same bore as the 720/730 but 8" stroke.
What would say a 9.75" stroke do to a 70 or 720 diesel? Just curious. I don't have the ambition or the money to even try.
JDGnut
08-05-2004 18:49:18
 Re: Stroking a JD 2-cylinder in reply to 720Deere, 08-04-2004 10:26:59
We have a friend that bought Weins old 730D... He bought it broke from them.. it had a broke rod and needed a new crankcase.. and some hair line cracks in the crank... after a new case, crank, rods and pistons.. he only got to pull it once and it broke the crank.. had another crank built.. and broke it... It can be done.. but it takes a dang good crank.. The crank Weins had build was much better than the 2 that broke... If you have a crank built.. have them build out from the journals as much as they will build.. And I don't think you will have enough room in a 70-730D for a 9.75 crank... I would try building a 820-830.. and put it on a serious diet.... Back to the 730D... in the hook last month there was an engine for sale.. 730D crank, block, piston, rods... I believe it make 49?cid... All I can say.. lots of fuel.. and head work.. and they pull pretty good... JDGnut
JD B
08-05-2004 08:50:40
 Re: Stroking a JD 2-cylinder/ Late Style stroked t in reply to 720Deere, 08-04-2004 10:26:59
I have a late style B stroked to 8".
JD B
08-05-2004 13:49:54
 I have a late style JD B stroked to 8. in reply to JD B, 08-05-2004 08:50:40
314 cu.in.
720Deere
08-05-2004 16:25:27
 Re: I have a late style JD B stroked to 8. in reply to JD B, 08-05-2004 13:49:54
That's cool, but what does it have to do with stroking a diesel?
