ChadS
08-19-2004 11:14:47
Re: ChadS: Need Info in reply to Buzzman72, 08-18-2004 15:48:35
Parts list: 460 flywheel, clutch plate Super H clutch disk H pilot bearing H throw out bearing 460 bellhousing plate,, utility, and industrials work too.. You will have to re machine the flywheel, to change the starter ring from the 460, over to the H ring, then stock H starter can be used. Now, here is where you run into trouble,,, the front frame rails,,, the H rails would have to be extended 10 inches or so,,, or just use 460 frame rails, they bolt right on the H bellhousing, and the stock front 6 cyl engine mount works with no alterations. otherwise,, been thinking of the H metal too with mine,, but,, the ol 460H is sitting quietly in the barn, waiting for another creative streak. LOL. other than the flywheel starter ring modification,,, it all bolts together. email me if you need any thing,, I have parts to build another one,,,,, LOL See ya. ChadS
