straight pipes
BUBBAH
08-21-2004 18:00:34
do straight pipes burn up valves in engines because there is no back pressure???
Kevin
08-22-2004 20:39:25
 Re: straight pipes in reply to BUBBAH, 08-21-2004 18:00:34
That is a very good question, i was just about to ask it.
I hope buikanddeere is right becuase im going to throw a straight pipe on my h tommorow now.
buickanddeere
08-21-2004 21:16:28
No, it"s an old wives tale. Usually it"s an old engine on it"s last legs that someone put a pipe on and began horsing it around. Of course the pipe gets blamed instead of the high hours or the aggresive operator. You will go deaf. If the engine runs leaner due to less back pressure. The mixture will have to be richened in order to restore max power and reduce exhaust gas/exhaust valve temps.
