WHITE PIPE
BUD BARENIE
08-22-2004 14:10:37
QUESTION :
SEEN SEVERAL PULLING TRACTORS WITH THE INSIDE OF THE EXHAUST PIPE (WHITE) IN COLOR.
WHAT TYPE OF FUEL IS CAUSING THE EXHAUST PIPE TO RUN WHITE !
THANK'S FOR RESPONSE
dej(JED)
08-23-2004 09:57:57
 Re: WHITE PIPE in reply to BUD BARENIE, 08-22-2004 14:10:37
MTBE (Methyl Tertiary Butyl Ether) will turn the pipe white.
John R.-IL
08-23-2004 16:55:50
 Re: WHITE PIPE in reply to dej(JED), 08-23-2004 09:57:57
And give you cancer and polute ground water. BAD stuff.
720Deere
08-23-2004 18:17:46
 Re: WHITE PIPE in reply to John R.-IL, 08-23-2004 16:55:50
Big mess going on in Fallston, MD with MTBE well pollution. About 5 miles from me, an Exxon station has polluted over 60 wells and counting. Exxon has been installing carbon filtration systems in affected homes within a 1 mile radius. The scary thing is that the station still is well within the leakage or ground concentration limits. I read somewhere that MTBE can travel through the pores of steel.
The county this is located in has issued a ban on all new gas stations located in areas serviced by well water. Maryland Department of the Environment has been testing hundreds of gas stations throughout the state and quite a few of our politicians are trying to pass an MTBE ban.
BUDD
08-23-2004 05:15:13
I is racing gas with lead.
Case1950
08-22-2004 18:35:19
I used to run av-gas in one of my old trucks. The lead in the gas would cause the inside of the pipe to turn white. It was 100LL (low lead), which really has a lot more lead then what was in the old regular gasolines for cars. You can get it at any small airport. The last time I worked at a small airport it was $2.25 a gallon which was 10 years ago.
Case1950
oliver 880
08-23-2004 08:15:08
 Re: WHITE PIPE in reply to Case1950, 08-22-2004 18:35:19
The white coating has nothing too do with lead..it is cause my your air/fuel mixture, white is normaly LEAN...
Jerry B
08-24-2004 12:09:21
 Re: WHITE PIPE in reply to oliver 880, 08-23-2004 08:15:08
Lead WILL turn pipes white.
BUDD
08-23-2004 10:14:51
This is just from what I have learned over the years (does not make it a fact though) You can not get your pipe to turn white or light gray with todays unleaded gas. It does not matter how lean you go. Back when there was lead in the gas you could always tell if the motor was a good one by the tail pipe color light color meant that it did not use oil. I have never seen a pipe turn anything but black in todays gas.
BUDD
BUD BARENIE
08-24-2004 05:15:34
 Re: WHITE PIPE in reply to BUDD, 08-23-2004 10:14:51
THANK'S FOR THE REPLIES!
SO IT'S BASICALLY AV-GAS OR RACING FUEL
ChadS
08-24-2004 08:58:16
 Re: WHITE PIPE in reply to BUD BARENIE, 08-24-2004 05:15:34
Bud, I bet I know which tractor you are talking about,,,, I dont think it is in the fuel in his litte front tank on it that is causing it, look closer to the big ol LP tank still on the tractor, makes me wonder what is in it? Just my 2 cents,,, ChadS
BUD BARENIE
08-25-2004 17:31:46
 Re: WHITE PIPE in reply to ChadS, 08-24-2004 08:58:16
I WAS IN REFERENCE TO A BOARD MEMBER PULLING FARM STOCK IN OUR CLUB!!!
UNDERSTAND I'M NOT PULLING THIS SEASON, BUT I AM OBSERVING THE SITUATION, FOR NEXT YEAR'S DRAG RACING !!!
Mopower
08-24-2004 12:13:22
Propane will leave white residue over time I believe. Usually very clean!
ChadS
08-24-2004 09:08:26
Also, our club needs to have a tech crew, and, they should know what to look for. Would be amazed on what a tech person will find, if he/she inspected the pullers more closely. ChadS
