tires
billy
08-30-2004 11:37:43
I see at the pull the side walls on some tires ripple and some dont. is that the ply of the tire the air pressure or is there something you put on your tires to soften them thanks for the help
Jak
08-30-2004 14:23:37
 Re: tires in reply to billy, 08-30-2004 11:37:43
It could be both tire pressure and/or type of tires.Some tires have soft sidewalls and will wrinkle even at higher pressures.The hard tires I run don't wrinkle with 15psi in them.
Jeff Oliver
08-30-2004 15:01:58
 Re: tires in reply to Jak, 08-30-2004 14:23:37
I've seen your tires, You might ought to hope that they DON"T wrinkle!! LOL!!!!From what I have seen in the videos mine wrinkle pretty good on about 12 pounds.
Jak
08-31-2004 08:00:23
 Re: tires in reply to Jeff Oliver, 08-30-2004 15:01:58
I like to keep my pressure close to manufactorer specs unless the track is super loose.I loose a lot of drawbar height with saggy tires after weight is added at 12psi and under.Jeff your right the tires I have now don't need to wrinkle much but thats ok,when they do your losing drawbar height.
