stroking a 730
730-LP
08-30-2004 21:37:08
I have a 730 LP that I would like to stroke,how much can I go with out going into the transmisson? is there any rods that could be used that would not have to be cut? The lp"s have a steel crank would that be a problem? any help would be appreciated thanks
JDGnut
08-31-2004 13:39:00
 Re: stroking a 730 in reply to 730-LP, 08-30-2004 21:37:08
Not too many 720-730 strokers out there... I don't know of any that you can build without welding the rods. The Case 504 rod works on a offset grind... The problem with these tractors is the short block... and the small cubes that you start with..
JDGnut
