ChadS
09-05-2004 09:39:16
Re: Need some advice for a tune up on a M in reply to ChadS, 09-05-2004 09:07:11
IH, H-450 governors. In my opinion, one of the best governors you can ask for on a puller. Too bad, they cant interchange with other colors,LOL!! There is a few different styles of the IH governor. A 2 weight and a 4 weight governor. The 2 weight system to me is the best to use on a puller. With very little modification,, it can be tuned up to be as sensitive as a $300+ rocket governor, for less than 30 bucks if the governor is in good shape. One of the biggest problems on both governors is there is not alot of room for rpm increases. Another is not keeping the carb open all the way when it is under a hard pull on the engine. Did you know, that under a hard pull on the engine,, the Stock IH governor shuts the carb down as rpms drop? I am talking about when you are hooked up to the track, and you power stall it. As the rpms drop, the governor spring is weak, and the low spring tension lets go, and allows the flyweights to shut down, RESULT,, the engine dies off at a faster rate because the governor gave up and shut the carb down. All you have to do is change out the governor spring. Now granted,, you can go to the hardware store 50 times, get frustrated, and maybe find what you need. Or you can get one from me,,, or the competition, either way,,, Like I mentioned before about the response time in the distributor advance, the same thing applies to the governor. A stiffer spring, speeds up the governor speed operation, making it more sensitive to rpm, and throttle responce. Combined, the distirbutor mods I mentioned, and the spring, you are looking at almost tripling the response time the engine goes from idle to full throttle rpms. Also, the new spring will hold the rpms longer under a load, instead of it falling on its face, it will hang in there a bit longer before it gives up and stalls out. Assured, the carb is open all the way, even after it dies, before,, it would be shut down due to the spring shutting it down as I mentioned before. As I mentined also,, the 2 weight governor is the best for stock or modified engines, in an IH,,,. The 4 weight, M&W style is a lazy governor, now granted they do work,, but the reponse time is very very slow VS the 2 weight. Also the 4 weight is harder to get over 2000 rpms out of it, with out having to readjust the linkages, or grind the weights down so they are lighter. You find the 4 weght governors more common in Super series tractors, I think it was possibly an option towards the later years of production. Granted the 4 weight will hold a more constant, steady rpm when it reaches full throttle, but it reacts so slowly, it is not really a good performance part for a constanly changing engine speed in a pulling tractor. Response time in the engine controls. Say it over and over,, LOL!! Next post will be Marvel Shebler Carb modifications for the SuperH-450 Farmall. ChadS
