ChadS
09-08-2004 12:01:51
Re: Chads Fuel problem in reply to cbice, 09-08-2004 11:35:56
Could be a few things to factor,, Humidity in the air, can change the air quality. A piece of dirt on the needle seat partially blocking it above the needle itself, If all of your tracors did this, then it is something common amongst all of them. (weather) Check your fuel flow coming out of the line, and through the neddle seat. should run pretty freely. You can either remove the carb bowl to see that, or open up the drain plug if it has one. If the carb was hot, it may have warped the floats in them, and hang up on the sides, Did they flood over out the breather pipe? Check the plugs for color, black, too much fuel, brownish,, is OK, and whitish color is lean, that will tell the tale if it a fuel delivery problem. Before you check the plugs, work the engine some how, ride the brakes, or something, shut it down, and look at the plugs. ChadS
