rpm's out of my WD
Allis Puller
09-08-2004 15:52:08
I can't get a straight answer out of anyone on how to get more R's and still get it to idle down
Puller504
09-09-2004 20:03:26
 Re: rpm's out of my WD in reply to Allis Puller, 09-08-2004 15:52:08
Maibach Tractor in Sterling Ohio has D-17 govenor spring and plunger sets in stock for about $11. Raises RPM's from 1400 to 1750. 1-800-808-9934 or 1-330-939-4192. www.maibachtractor.com, it worked for me! Hope this helps, Don
Allis Puller
09-10-2004 09:49:05
 Re: rpm's out of my WD in reply to Puller504, 09-09-2004 20:03:26
I'm already running a Gleaner motor turning that much. What I'm looking for is close to 3000 rpm's. But thank you anyways.
allis man
09-09-2004 07:45:04
get governor spring out of 175 allis it will give you all the rpm's you want
ACWC
09-08-2004 16:50:33
you can adjust your external linkages to a certin point, and then you will have to use a stronger spring in the gov housing and or lighten the weights.
