which tractor for starters
Ben Rauls
09-09-2004 18:49:03
I'm looking at buying a tractor in the next year or so, mabey sooner. I want to start pulling. I'm looking for something i dont have to stick alot of money in it. i'm not looking to get super competive just for fun. Ive been doing alot of reading here on the farmall M's. Any pro's or cons? thanks guys.
Ben
Mopower
09-10-2004 06:17:51
 Re: which tractor for starters in reply to Ben Rauls, 09-09-2004 18:49:03
Ms are good but I'd suggest a Moline U. Fairly cheap, 5500 pounds, and with only a set of new bigger bore blocks, you can be very very competitive. It is the cheapest tractor to pull. If down the road you wanted more, very easy to change. M-M engines are interchangeable like legos. A bored out Farmall M with high compression heads tuned right can compete quite well do, but more money. A DC Case is good but more money to modify too.
