Rules for Tunica Miss
Brad L
09-20-2004 18:55:00
What are the rules and classes for the Tunica Mississippi pull? Thanks Brad
Spotter
09-21-2004 10:39:32
 Re: Rules for Tunica Miss in reply to Brad L, 09-20-2004 18:55:00
These are the rules and classes that we pulled last year. They will be essentially the same. I will post final rules and classes on www.greenpullers.com as soon as all is finalized. Sorry this post did not format as the brochure was shown but you should get the idea...Spotter
SOUTHERN NATIONAL RULES
TUNICA, MISSISSIPPI
December, 2003
Mean Green Pulling Team and Fitzgerald’s Casino
Farm Stock II Classes
Pre-1960 Tractors with stock engine... No cut tires... 18.4 X 38 Maximum size... Hang on weights permitted... a maximum of 10% over stock RPM** is allowed... Wheelie bars are mandatory... 1st. Gear only. 4mph maximum.
4 MPH & 8 MPH Classes (modified)
Pre-1960 Tractors with internal engine modifications...Spacer plates, girdles, power blocks, 12 port heads...800 heads and jugs are allowed... All parts must be on tractor origin...18.4 X 38 max. tire size...any cut, any rim width...no duals...Weights: 11' from center of rear axle to furthest point of front weights...Rear weights must not extend beyond rear tires...a maximum of 20% over stock RPM** is allowed...Any gear, 4 MPH Max and 8 MPH Max...20" draw bar height, 18" back from rear axle...Wheelie bars & breakaway switches are mandatory...No alcohol, no nitrous, no turbos, no blowers.
No Speed Limit Classes
Same as above except a maximum of 30% over stock RPM** is allowed.
All Classes
No V-8 engines allowed.
**Stock RPM is calculated on the tractor of origin’s stock engine specifications as published by the tractor manufacturer.
Speed limits begin when any part of a tractor passes the orange cone at ½ track. Tractors with side shields may be inspected prior to pull.....If a protest is made, it must be made before the end of the class. Protestors tractor will be examined first. Then and only then will the protested tractor be checked. Mean Green officials reserve the right to inspect a tractor at its discretion.
PULLING ORDER
(Only 3 pulls per tractor for 2 days)
FRIDAY SATURDAY
Farm Stock II Modified Modified Modified
(Green Sled) (Blue Sled) (Green Sled) (Blue Sled)
4500# 4 mph 6200# No limit JD King of the Hill All other King of the Hill
5500# 4 mph 7200# No limit 3500# 4 mph 6500# 8 mph
6500# 4 mph 7500# 4 mph 3500# 8 mph 6500# 4 mph
7500# 4 mph 7500# 8 mph 4200# No limit 5500# No limit
10,000# 4 mph 4500# 4 mph 5200# No limit
4500# 8 mph
5500# 8 mph
Have fun and keep in mind this is not a political event or debate!!
Puller
09-21-2004 16:27:29
 Re: Rules for Tunica Miss in reply to Spotter, 09-21-2004 10:39:32
What classes will be pulled on Friday?
I heard the no speed limit classes were going to be changed to 12 miles per hour. What happen?
Brad L
09-21-2004 17:52:30
 Re: Rules for Tunica Miss in reply to Puller, 09-21-2004 16:27:29
Thanks for all the info. I hope it does change to 12 mph. Brad
P.T.
09-21-2004 17:57:24
 Re: Rules for Tunica Miss in reply to Brad L, 09-21-2004 17:52:30
They'll lose lots of pullers if they make the "no speed", a 12 mph class. Just because they can't enforce the rpms with Mo Money, etc, the 12 mph speed won't help. If your rules says 30%, be men and tell the highwinders this is no pull for them. A lot of people were hoping you wouldn't screw this pull up, well you're on your way!
Tunica Puller
09-22-2004 07:02:31
 Re: Rules for Tunica Miss in reply to P.T., 09-21-2004 17:57:24
We traveled to Tunica to find that there program is pretty much "run what you brung" and take care of the good ole local boys. If USAP wants to be associated with this group Mean Green should look at there program and follow suit or USAP should break ties as there two programs are much different. I am not sure who is greasing who? Just gives USAP a bad rap. We expected it to be a similar program. I guess if the Tunica folks are happy with there program it just as well stay the bush pull it is and see how it fairs in years to come. Good facility and good folks, they just need to stiffen there backbone and run it fair for everyone. Nothing kills a program faster than the lack of rule enforcement!!
Hillbilly Hooker
09-22-2004 20:28:36
 Re: Rules for Tunica Miss in reply to Tunica Puller, 09-22-2004 07:02:31
Hey Ray Charles, I have been to the Tunica Pull for the past 4 years and I would have to say that they run the fairest and by far the best pull in the Midsouth. Evidently it didnt go your way. But by the number of hooks they had last year someone liked it. I havent noticed any numbers like that at any NATPA pulls. I know they dont play any favorites for the local boys as most of them dont get the chance to really concentrate on there pulling cause they are working there butt of so the rest of us can enjoy the pull! So quit whining and degrading there pull. Its your choice if you come or not. H.H.
Spotter
09-22-2004 16:34:46
Puller,
Mean Green is not associated with USAP. We have tried to simplify rules to make it an enjoyable outing for everyone rather than it being a game of "catch me if you can" regarding the rules.
The good ole local boys have hardly been taken care of. We have had our rear ends kicked royally since the inception of the Tunica pull. The number of times any of our people have even placed in the money could probably be counted on one hand.
Our bush pull counted over 700 hooks last year so we'll probably keep things as they are for the time being. I would point out that, to my knowledge, we have had no major protest due to rule infractions.
I just learned that the no speed limit classes will, in fact, be 12 MPH this year. Just thought I'd pass that along since I wasn't sure about it being finalized until today.
Hope you can make it again this year....Spotter
Puller
09-22-2004 13:54:52
I agree with you, what ever your rules are inforce them!!! People may not like all of your rules but they will respect you knowing that everyone will be treated the same. This is very important through all aspects of life.
NOTSIP
09-23-2004 04:38:59
 Re: Rules for Tunica Miss in reply to Puller, 09-22-2004 13:54:52
my thoughts the pull is #1, but the emenities are out of this world, it all goes back to the dog who barks 1st. an loudest is the one with his ba--s in vise
Spotter
09-23-2004 07:51:16
 Re: Rules for Tunica Miss in reply to NOTSIP, 09-23-2004 04:38:59
Notsip, You have such a way with words. Oh, I've been meaning to warn you. If they ever give you a speaking part in the movies, be sure not to accept any where the script calls for you to "squeal like a pig". Your fellow actor, Ned Beaty, made that mistake and lives to regret it to this day...Spotter
