Splined Hubs for JD
ChadS
09-22-2004 07:45:12
Just wanted to tell ya all that we are making splined hubs, for any JD 2 cyl splined rear axle. It is an exact fit to the splines, build your own 9 bolt adapter ring to this hub, and you have a light set of weld on,or??? rear hubs for your JD pullers. ChadS
ChadS
09-22-2004 09:23:15
 Re: Splined Hubs for JD in reply to ChadS, 09-22-2004 07:45:12
Making them for any 2 cyl JD, actually, any axle design period. From B to ???? IH,, any of em. It will be an exact spline for your axle. They will slide on the axle, and if you choose to weld the hub to the axle, pin them, or whatever,, they will be stronger because you are using the entire spline of the axle. Will give ya a choice,, you can either just get the hub, that fits the axle,, and make your own plate for the rim, (which would be cheaper) or we can make the entire hub for you. ChadS
toot
09-22-2004 09:58:11
 Re: Splined Hubs for JD in reply to ChadS, 09-22-2004 09:23:15
Price?
ChadS
09-22-2004 10:15:48
 Re: Splined Hubs for JD in reply to toot, 09-22-2004 09:58:11
$225 for the set of axle hubs. These are cut on an EDM. Any model of JD. ChadS
austin99
02-21-2005 17:32:39
 Re: Splined Hubs for JD in reply to ChadS, 09-22-2004 10:15:48
Please send me your phone # and I would like to talk to you about a set for a G JD.
Thank you
Jason Crots
09-24-2004 18:57:04
Would like a set of hubs for a 1950 J>D>G
Please E_Mail Ph. NO> thanks Lynn
ChadS
09-22-2004 09:48:55
 Photo of hubs in reply to ChadS, 09-22-2004 09:23:15
third party image
Here is a photo of what we have. ChadS
Jdtruble
09-22-2004 09:15:09
Are you making any for the "G" or just the A's and B's?
gpuller
09-22-2004 09:13:49
Chad do you have some pictures you can post? Are they weld on only?
