JD lp head/more power
630 puller
09-24-2004 13:47:08
can anyone tell me where I can get a 630 john deere lp head, and which way would be better to go for more hp, destroking, or stroking it...any other suggestions would be great, thanks
G-MAN
09-24-2004 15:32:15
 Re: JD lp head/more power in reply to 630 puller, 09-24-2004 13:47:08
The LP head is only different from the gasoline head in the fact that it had hardened valve seats. Otherwise it was identical and is the same casting number, and will gain you no more power over the gasoline head. Deere LP tractors gained their higher compression ratios purely by piston design, not by smaller combustions chambers as on some other brands.
Ironman
09-25-2004 20:38:31
 Re: JD lp head/more power in reply to G-MAN, 09-24-2004 15:32:15
ditto what G-man said, and also the only reason you might want to destroke it is if you were wanting to turn some serious RPMs. Otherwise you want to stroke it.
630 puller
09-26-2004 17:20:06
 Re: JD lp head/more power in reply to Ironman, 09-25-2004 20:38:31
thanks guys, I'm considering high rpms, but I will not look anymore for a lp head....thanks again.
