Carb troubles on G
36 A
09-28-2004 17:25:01
Just got my carb back from getting overhauled. It runs nice but when you throtle up off idle it stumbles and smokes.I've played with the needles and can't get the smoke or stumble to go away .I can get it to smoke more and stumble more but not much less.Any thoughts or questions .36 A Thanks
lynn
09-29-2004 14:12:14
 Re: Carb troubles on G in reply to 36 A, 09-28-2004 17:25:01
36 A..my a with a 51 does the same thing.. i got it to do a little less by measuring the gas in the bowl and adjusting the float..runs good..pulls good..hand cranks too..lynn
Jak
09-29-2004 08:08:21
Make sure you don't have Champion plugs in it.Use Autolite or AC plugs.Are you still using the oil bath breather?Dirt dobbers can wreak havoc on the breather spouts.Let us know what you find.Jack(TN).
ChadS
09-30-2004 09:03:08
 Re: Carb troubles on G in reply to Jak, 09-29-2004 08:08:21
It does sound like the ignition, Plug gap??? weak spark, and wrong plug gap will cause that in a 2 cyl. ChadS
ChadS
09-30-2004 09:05:15
 Re: Carb troubles on G in reply to ChadS, 09-30-2004 09:03:08
Also make sur the load adjustment is not too rich,, will make it stumble, try to set the load adjustment onthe carb, with a load on the engine. They can be finicky. Chad
36 A
09-29-2004 19:10:28
Not sure the # but they are AC plugs.I was tring to use a paper element but it is unhooked now.The motor is 125 over fresh build ,elect. ign.i've tried 3 carbs now with 3 different results.Might have to wait till next year to test more cause pulling is over. Thanks 36 A
Jak
09-30-2004 10:39:32
 Re: Carb troubles on G in reply to 36 A, 09-29-2004 19:10:28
How was your valve guides and intake valves.I had a 53 G that stumbled like that and my intake valves were beat up pretty bad and the guides were shot.I would figure that you had the head worked when you rebuilt but I thought I would ask.I used C 87 AC plugs in mine with a pertronix ignition and had good luck.Wish you luck,Jack(TN).
