ChadS
10-02-2004 10:09:07
Ok, Sorry for the off topic here, My 93 F-350 died on me. Need some help,, What had happened, was, I got some bad fuel from the station, and had a lot of water in it. I had to drain and flush out the fuel system,, I cant seem to get the injector pump bled to the injectors now. I had tried to use the starter to rotate the engine to prime the system, but,, that is alot of wear and tear on the starter,, and to no avail, still wont pump up,, Got fuel to the pump, but wont bleed through,,, What is happeneing here? Is the pump not priming because of the slow rate at which the starter rotates the engine? Even if the stater could handle cranking it,, it would probably take 1 hr or so to actually prime it,, any ideas on how to get it going?? I have not ruled out the pump going out,, but it ran the nite before after changing the bad fuel out with new,,, I had shut the engine off, and would not start the next day, I opened up the lines to the injectors,, nothing there,,, is it being a (^&%^*(&^ to bleed, or should I look for a new pump? Any info would be great! Thanks, in advance,, ChadS
