Re: john deere A
Tim H
10-03-2004 05:52:58
Wow!!!! So then you have to have pistons made, that has the wrist pin holes moved forward, right?
Thanks for the reply
Tim
Drew
10-03-2004 09:58:43
 Re: john deere A in reply to Tim H, 10-03-2004 05:52:58
Depending on the individual engine combination, you may or may not have to have pistons made. If you can find a piston from another application and close to the right wrist pin size, they can be made to work. It may require that either the piston or the connecting rod have bushings made so the piston and rod share a common wrist pin diameter. Then connecting rod length can be adjusted accordingly to come up with the right compression ratio. A drawback to using John Deere pistons in a stroker is that they have a tall compression height that does not allow for a long connecting rod and can also create problems in long stroke engines with pulling the wrist pin out of the bore at BDC.
