constant mesh gear for m
big t
10-14-2004 16:51:53
is the constant mesh gear in all m w6 o6 the same or is there a difference i want to speed up a m already have w6 ring and pinionin it if there is some faster what are they?
DWV
10-15-2004 13:35:51
 Re: constant mesh gear for m in reply to big t , 10-14-2004 16:51:53
Those tractors all have same gear ratio constant
mesh gears.May be something in industrial im not aware of.SM second,third and forth faster than M,
but you have to change most of gears,countershaft
and reverse idler gear to use in M.MTA and hundred series gears do not fit.Best thing is probaly to use a M&W 9 speed in good condition.
Flyin Farmall
10-14-2004 17:20:02
Super M or 400 gears are faster,than a "M".they should speed you up quite a bit with the W-6 gears.
