super m winter project
bobo
10-28-2004 11:26:31
i have a super m that each winter I do something to it. I have done most everthing over the years and now I am at the point leave it alone or stroke it. the only thing that I could do on the stock stroke is to raise the compression I have 150 psi now .it runs pretty good now i pull in 3rd gear and do good. so what do you think . raise the comprssion or just stroke it and be done thanks
ChadS
10-31-2004 06:25:10
 Re: super m winter project in reply to bobo, 10-28-2004 11:26:31
I had a Super M in the shop yesterday, It had a 264ci, with an LP head, 200 psi of compression, made 75 hp at 540. So, that gives you an estimate on what the LP heads can do for your Super M. It had plenty of potential for more HP, but his fuel was not good enough to get him there. We are making pistons that can make around 180-200 psi with stock bore, with the super M-450 head. The options for this engine are wide spread, Me, I am a fan of small cubic inches with high compression to make HP on a budget. ChadS
jjgmc
10-28-2004 18:44:00
I too have a super m winter project puller and I am thinking of what route I want to go too
Flogger
10-29-2004 04:42:32
 Re: super m winter project in reply to jjgmc, 10-28-2004 18:44:00
Both of you guys should check out the farmall project engine LW and Casepower are building in the Oldpowerpride mag. I think they're figuring on about 100 HP.
jjgmc
10-29-2004 15:46:33
 Re: super m winter project in reply to Flogger, 10-29-2004 04:42:32
yeah I am read on that build up very good reading 100 + horse is what I am after How long will the build up take?
LW
10-29-2004 17:25:23
 Re: super m winter project in reply to jjgmc, 10-29-2004 15:46:33
About 2 more issues
ChadS
10-30-2004 07:05:11
 Re: super m winter project in reply to LW, 10-29-2004 17:25:23
I read that,, cubic inches with low compression. I think it would be a pullin machine! Nice long torque curve. I sure did like that MM I seen in the OPP. ChadS
jjgmc
11-01-2004 15:38:39
 Re: super m winter project in reply to ChadS, 10-30-2004 07:05:11
I see in the article your using a 450 gas head. Will my super m head work or do I need to find a 450 gas head
ChadS
11-02-2004 06:42:05
 Re: super m winter project in reply to jjgmc, 11-01-2004 15:38:39
You can use the Super M head. It is the same casting as the later heads. The one I tuned up over this weekend, had an LP head on it. Most tractors that have not had any work done to the carb, governor, and distributor, there is power hiding there,, alot of power. See, your Super M has the good cam, cyl head and carb all ready on the tractor, so you have an engine that has a higher torque curve over most. If you need more compression,, I have stock bore pistons that will get you up to 180 psi easily.. ChadS
jjgmc
11-02-2004 15:42:14
 Re: super m winter project in reply to ChadS, 11-02-2004 06:42:05
what are we look at far as power with 180 psi. how much horsepower do I need to turn 18.4 38 tires and in what gear thanks
ChadS
11-03-2004 06:55:08
 Re: super m winter project in reply to jjgmc, 11-02-2004 15:42:14
At what weight? One thing to consider on the Super M, was they had faster transmission gear in them (2nd gear-4th) Low gears were close to the same as the M. Lets talk HP for a moment. First, lets start with the M's the M will not make as much HP as the Super M with the same pistons I have. Now one can get the upgrades to make the M match the super M potential, but that involves, Using the same cyl head, and the cam that the Super M-450 uses in the M engine. The old cyl heads, (8060D high compression gas M head) those compression chambers are deep. Much more cc's than than the newer style cyl heads. so you dont gain as much compression using the M head as you would the Super M-450 heads. The M cam, is the old cam grind, it does not create the torque that the newer cams do, I seen that on the dyno right off the bat, All, Super M-450 that I have dynoed, all will have a 20 hp torque curve below 540 and then drop off hp, the M will only have 12-15 hp jump before it falls off. I call that "lugging power" (this is after I rejet the carb, change the governor spring, and calibrate the timing on the dyno) And I'll tell you how to tune it just like I did for everyone else it is easy, and will save you alot of $$, and headaches. more on that later,, LOL. HP estimate for the M's and I use estimate because not all M's are equally strong in HP no matter what any one says. My pistons in the M's will make 150 psi with a 4-1/8 bore, that makes it a 281ci in. 65 hp, using an 8060 head and M cam. That is with the carb rejetted, 94 octane fuel and the governor spring, and the distributor in good shape. I only offer 4-1/8 bore, small wrist pin pistons for the M-450. Now with these pistons in the Super M-450. Still 281 cubes, but now the good cam, and the newer cyl head is added to spice things up a bit. (which is what you have if it a Super M) The newer cyl head will make 30 psi more than the old 8060 head. So that bumps it up to 180psi, (with a stock not milled cyl head from the SM-450) But the engines charateristics are much better. The head and cam really brings the engine to life. A stronger torque curve, more HP at 540 from the difference in compression pressures, cyl head design and the cam grind. In my opinion, the Super M-450 tractors are the ones to pull inthe heavy classes VS the M cause they can hang on longer in the lugging. Simply put, these engine have more torque in the rpm ranges below 1300 engine rpms. With 281 cubes, 180psi, good cam and head, properly rejetted carb, timing, and governor tuned, 72-75 hp at 540. With the potential for more!!! You could mill the head and get it up to 200 psi and be stronger yet! One thing I want to point out, is that you cant just slap these things together and go pulling and expect them to be right, right off the bat. The tractor, is as good as the work YOU put into it. So if you want to do the little work that makes them great, I and everyone here on this site will be more than happy to help. Sure they wont like it if you take their money,, but hey,, bragging rights rite?? LOL. Give or take a few Hp because it depends on the fuel you use in them. ChadS
jjgmc
11-03-2004 15:42:41
 Re: super m winter project in reply to ChadS, 11-03-2004 06:55:08
5000 and up This engine is in need of a total rebuild it is pretty tired. Are we running race gas or at least 93 due to compression. All I am doing is kicing around ideas at this time thanks for the imput? Would you like a pic of the tractor as it is now?
ChadS
11-04-2004 06:54:47
 Re: super m winter project in reply to jjgmc, 11-03-2004 15:42:41
Sure! Pictures are good! 94 octane will be the starting point for octane levels. Should be a bit better than pump gas though. I recommend finding a fuel with ethanol in it. will help with octane, and preigntion, and detonation, and if you find a good source, it sometimes is cheaper to run than the 4-5-6$ a gallon racing gas. Thanks for looking, hope it gives ya some food for thought! Any questions just ask. ChadS
