Highest HP from an Oliver 88 Diesel based motor
AC
10-29-2004 07:58:55
Any ideas on how many "REALISTIC" HP can be attained from a stroked 88 diesel motor. No 7 main blocks, no turbo, no incredible block work. Guidelines: A maximum overbore in the block, big stroke, head work, pump and line work. Does anyone have any bore and stroke numbers?...just curious...AC
Puller
11-01-2004 05:12:35
 Re: Highest HP from an Oliver 88 Diesel based moto in reply to AC, 10-29-2004 07:58:55
I have one that is 4-1/4 x4-1/2 stroke, 2-5/8 rod journal, generates 600 ft. of torque on new dyno. It has a roosa master pump with 5020 JD head in the pump. It is very fun and different.
AC
11-01-2004 09:26:54
 Re: Highest HP from an Oliver 88 Diesel based moto in reply to Puller, 11-01-2004 05:12:35
what class do you pull it in and where?...AC
Puller
11-01-2004 10:37:33
 Re: Highest HP from an Oliver 88 Diesel based moto in reply to AC, 11-01-2004 09:26:54
I pull div. 3 NATPA rules in central KS.
JDGnut
11-01-2004 13:27:42
 Re: Highest HP from an Oliver 88 Diesel based moto in reply to Puller, 11-01-2004 10:37:33
Does the 88 still have the air/power cells?? Did you modify these cells any??? JDGnut
Puller
11-02-2004 10:51:46
 Re: Highest HP from an Oliver 88 Diesel based moto in reply to JDGnut, 11-01-2004 13:27:42
Drill the power cells out two more drill bit sizes bigger to match the cu. in. that the engine has increased. It lets more fuel into the back of the chambers so that it will burn. Before I did this it smoked coal black, now it is just right.
