MOPOWER,, ChadS here,,
ChadS
10-31-2004 06:31:10
Well pulling season has been over for a few weeks now,, but that little small block MM i got is begging to be set free from the garage for a few days.... So,, well with no sleds in sight, gonna go back to basics,, Put er in the field. I dug out our keewanee 12 ft disk, gonna see if that ZAU can pull it!! I think it might,, So, working on the MM this week!! ChadS
Lorin Cook
11-01-2004 10:36:55
 Re: MOPOWER,, ChadS here,, in reply to ChadS, 10-31-2004 06:31:10
I have attempted to send you a few e-mails,but I guess you have a spam eleminator which is fine, so do I. My question, on a Farmall H, can I successfully remove the sleeves from the engine and use the block as the cyl. wall and bore it to 3.75 to 3.90 with out going through the wall and have a successful rebuild? You also once mentioned using 806 pistons, could they be used with an LP head? thanks for your comments.
ChadS
11-01-2004 13:04:26
 Re: MOPOWER,, ChadS here,, in reply to Lorin Cook, 11-01-2004 10:36:55
You have mail! ChadS
Mopower
11-01-2004 05:53:49
Just got back from Greg Herriot in Illinois. Brought my GBD home. I also have a model R and 5 star coming from other folks. Should be enough for the weekend, but I need to sell the two Rs I have. Let me know how that big old disc worked! I am finding some parts to build a 335 now. Probably start on that next winter. My R, U, and J need finishing first!
