How much compression is too much?
anothertractor
11-10-2004 05:03:09
Hey yall, the tractor needs a little sprucing up this winter and I need to ask a questions about compression. Lets say that you have a 4 inch bore and 4 inch stroke, (824CC). If you have an 82.4 cc compression chamber, is this a 10:1 compression ratio? Also, how high should I try to get the compression? I am looking at getting some rods made to get the compression just right and I am not exactly sure how high I need to get the piston. Thanks for any help.
anothertractor
11-12-2004 04:46:39
 Re: How much compression is too much? in reply to anothertractor, 11-10-2004 05:03:09
Thanks for everyone's help. I think I have a plan now.
tony smithson
11-10-2004 17:20:56
just put in a 45 crank and the same pistons, cheaper than buying rods.
buickanddeere
11-10-2004 18:24:21
 Re: How much compression is too much? in reply to tony smithson, 11-10-2004 17:20:56
Mechanical compression ratio or effective compression ratio? More cam duration requires more mechanical ratio to keep the same compression pressure.
i believe
11-10-2004 18:27:19
 Re: How much compression is too much? in reply to buickanddeere, 11-10-2004 18:24:21
I believe how to figure C.R., you:
(Volume or one cyl.+combustion chamber cc's)/combustion chamber cc's..
champspa
11-10-2004 15:49:10
your on the right track , just get it to 240psi cylinder pressure and that will be enough
anothertractor
11-11-2004 10:45:54
 Re: How much compression is too much? in reply to champspa, 11-10-2004 15:49:10
I figured that I would need somewhere in the neighborhood of 240 PSI but I am not sure how to calculate what I need to do by PSI. Is therea direct relationship between PSI and compression ratio? (like 12:1). I need to know what would be a good desired ratio or a conversion for PSI to the ratio figure. Can anyone help with this?
ChadS
11-13-2004 06:46:15
 Re: How much compression is too much? in reply to anothertractor, 11-11-2004 10:45:54
I was thinking about a scale on relitive compression pressure to the ratios, Here is what I came up with, it is just a guess, but I think is it real close.... Hope this helps,, ChadS
pulller
11-11-2004 16:31:22
12:1 is just potential. its a relationship in total cubes and combustion chamber size. THe valve size and cam types/settings make a big differance in compression psi. 12:1 is way up there.....most small engine builders shoot for 9-11:1...and then your talking another point on a larger motor..... ..lots of stress.....some cars have up to 12.5:1, but never do get the compression figures up there right for the rpms they run....where a properly breathing tractor will be through the roof..... ..i would shoot for 9 or 10:1 compression ratio....
FARMALL
11-10-2004 06:25:34
To figure compression ratio properly you must use this formula:
(Head volume + Piston to deck volume(+or-) + Gasket volume)= Squeeze volume
Take cylinder volume+ Squeeze volume divided by
squeeze volume or simply go to www.compression ratio computation. Hope this helps
Farmall
