OT Dodge/ Cummins fuel problem
anothertractor
11-15-2004 11:40:43
Does anyone know where I can find a discussion forum to talk about a problem with a fuel problem on a 1999 Dodge 2500 with Cummings deisel? It seems that this truck looses fuel pressure when going down a long hill, like on an interstate. When you get ready to go back up the other side, it seems like it is not getting enough fuel pressure or something. The injector pump and fuel pump have been replaced. The Dodge dealership cannot figure out what it wrong with it.
Thanks.
anothertractor
11-17-2004 08:04:33
 Re: OT Dodge/ Cummins fuel problem in reply to anothertractor, 11-15-2004 11:40:43
Thanks for all the help guys.
JDGnut
11-15-2004 18:42:15
Get a fuel pressure gauge and hook it to the top of the filter housing.. one is before the filter.. one is after... Tape on the window.. (I have one window pillar..) Watch the pressure while you are driving... Don't forget about the tank.. you could have a problem in the tank.. Mine runes 12-15 at idle.. about 8 at WOT..
JDGnut
(no fuel shutoff on a 99.. VP44 powered..)
JoeMN
11-15-2004 18:13:28
Similar problem on my 1998 Dodge. Dodge dealer couldn't figure it out,local heavy truck shop did. The fuel shut-off solenoid was faulty,at 180,000 miles it was worn enough that it did not open completely when attempting to start engine. Sometimes hard to start,sometimes low on power,sporadic problems. New solenoid,no problem,the power is back!
joecool
11-15-2004 16:00:47
www.dieselinjection.net
www.pittsburghpower.com
champspa
11-15-2004 14:16:59
www.turbodieselregister.com
JDGnut
11-15-2004 12:14:34
It still sounds like your lift pump.. I can't remember if the VP's have an overflow valve...
Check out these sites..
Link
tdr1.com
JDGnut
