Width of rims
Angus
11-16-2004 19:39:55
Will a 17" rim be suitable for a 16.9" tire? I want to do this so i can switch 18.4's on if i want. Think it will be ok??
Mike Aylward
11-16-2004 19:50:59
 Re: Width of rims in reply to Angus, 11-16-2004 19:39:55
Angus, a 17" wheel will work very well with a 16.9 tire. They will work ok with an 18.4 although an 18" would be slightly preferable. I cut many 18.4's on 16" rims and they will work ok but most are on 18's. Best results are found with the rim and the section size of the tire being very close. This makes a straight sidewall which will support the tire and tread better and doesn't add unnecessary weight like a super wide rim does. Mike
MAD DUC
11-17-2004 03:12:02
 Re: Width of rims in reply to Mike Aylward, 11-16-2004 19:50:59
What about a 14 inch rim for 13.6 tires? I thought it would work perfect, but my local tire store says that's to wide for that tire.
Mike Aylward
11-17-2004 19:03:20
 Re: Width of rims in reply to MAD DUC, 11-17-2004 03:12:02
MAD DUC, I would think that rim would work. The factory recommended rim for a 13.6 tire is 12" wide. But it should work ok. Mike
