Radial tire for pulling
1256 puller
11-20-2004 04:40:35
We're going to pull an IH 1256 in farm stock next season. I picked up a pair of 20.8-38 radials with about 50% tread and good sidewalls.Are radials decent for pulling or should I get a pair of bias-plys?
Redman
11-20-2004 05:41:26
 Re: Radial tire for pulling in reply to 1256 puller, 11-20-2004 04:40:35
they work well until you start building on the hp,then they bounce.
i have no idea why they do it,but after around 400 hp they start.
Red Puller
11-20-2004 18:56:13
 Re: Radial tire for pulling in reply to Redman, 11-20-2004 05:41:26
Boy do I have to agree with Redman. I have them on a 1206 and run 3rd high + TA and it can get a little squirrelly. They hook great, but I rarely have a smooth run. Didn"t know that I could blame it on the tires. By the way, I run about 5 lbs more air pressure than my Bias tires.
air it up
11-20-2004 20:49:55
 Re: Radial tire for pulling in reply to Red Puller, 11-20-2004 18:56:13
I agree those guys with radials do a lot of bouncing. Keeping the air pressure stiff helps. Like Red Puller said you need a little more in a radial than you do a bias because they will give and squat a lot easier.
