JD G horsepower
1951G
11-23-2004 11:08:08
I wanted to get an approximate horsepower rating for my 51 G. I'm currently using the original cyclone head w/ .045 aluminum pistons, but I've found a flathead I was thinking of purchasing. I've also got a cold manifold (the flat looking gas manifold) on it. Would this be a good setup or is there something else that could be done besides stroking that would help on hp?
Thanks,
1951G
G-wiz
11-24-2004 08:55:30
 Re: JD G horsepower in reply to 1951G, 11-23-2004 11:08:08
I have G with .125 flat head port polished and big valves,carb opened up f1074 gas manifold port matched and a cam installed. I just put the cam in and dyno strong 75hp at rpm.I have to run race fuel for the comp increase.
2 Cylinder
11-23-2004 12:51:48
I have a 51-G with .090 over aluminum high compression pistons and the flat head, gas manifold. It dynoes 68-70 hp, it spark knocks on anything but aviation gas/racing gas. The flat head gave me about 7-10 more HP.
a puller
11-23-2004 16:34:05
 Re: JD G horsepower in reply to 2 Cylinder, 11-23-2004 12:51:48
we have a JD G with a flathead, .090 pistons, big nut carb, and a good port and polish job....65-70 horse..... ....used to run 70 all tyhe time.but head cracked from spark knock..... .so now its about 65-66 most of the time.....The advantage to getting a flat head is to boost the compression. if you could get a good set of pistons to boost u up to like say....9:1 compression ratio, then the swirl head would be better.....it has bigger ports and valves...and believe it or not, the swirling helps feed air/fuel and mix the air/fuel better..... .
1951G
11-26-2004 09:15:16
 Re: JD G horsepower in reply to a puller, 11-23-2004 16:34:05
A Puller,
Would a set of m & w .125 high compression pistons get the compression ratio up to 9:1? What if I shaved the cylone head down to the top of the eyebrows and used these pistons?
Thanks.
a puller
11-26-2004 16:06:51
 Re: JD G horsepower in reply to 1951G, 11-26-2004 09:15:16
i doubt it. It takes more then a bigger piston to get up the compression. it has to be a tighter combustion chamber hense the dome piston. i wouldn't mill the head either..you can always change pistons, once a head is shaved alot, its always gonna be shaved alot. better go with the piston changing and a GOOD port and polish idea. i couldn't tell you where to get a good piston or what to use since i have not done one myself like this. We have plans for one, but still don't know about pistons, and it will be a stroker if we do it. contact wtw...a guy that goes by lynn, or buickanddeere...there very knowledgable guys.
Ironman
11-24-2004 05:09:35
You're right about the swirl head being better. It will produce more torque than the flat head will.
