What will i need to pull my tractor?
Bruce
01-18-2002 17:16:52
I have a 46 john deere B What will i need to pull in the stock class for fun .Thanks
Slo
01-22-2002 12:11:41
 Re: What will i need to pull my tractor? in reply to Bruce, 01-18-2002 17:16:52
A clevis. That's if you are only pulling for fun... :-)
Seriously, a B is not an easy tractor, nor a cheap tractor, to build for competition. A friend of mine has one that does really well at 3250 and 3500, but he starts to run short in 4000. And he has done lots of work, and spent more than a couple bucks on, the little B. Too many tractors bigger than the little B when you get that heavy that are able to balance well.
WTW posts on here quite a bit, and he has a couple of B's that are pretty tough. Seen em Sigourney, and for B's they are wicked.
D Dude
01-22-2002 09:02:51
I have pulled agensted a B that half tracked my Super 88 Oliver. He had about $5000.00 in the moter.
Sounds like fun BUT
01-22-2002 01:09:43
i never saw a John Deere B pull anything successfully except a hay wagon. and then when its loaded, they wont climb anything without gearing down, even on pavement. Never hooked one to a sled. But have run them a ton, all over the place, lots of them, most everyone has one hooked to a haywagon. its about all they are good for.
but hey its your tractor, and i bet you enjoy it as much as anyone else here does theirs. who knows, right traction conditions the day may be yours.
Clint
01-20-2002 19:44:25
Bruce, It sounds like from the other responses, the first thing you need is a big ego. I usually pull Cases and do quite well. But I have a 47 JD B. I don't pull it with the light weights though. It takes home the gold in the 5500lb class. Most people don't think a JD B has much hope in this class- until they see it pull. At this weight it is perfectly matched with its mostly stock engine and 15.5 tires. Just grab a clevis and "come on down".
LL
01-21-2002 13:46:08
 Re: Re: What will i need to pull my tractor? in reply to Clint, 01-20-2002 19:44:25
Your either on a super slippery track or your just on something.
JD
01-20-2002 16:00:11
Well the first thing you should do is sell it and buy an Oliver. Even with stock tractors the Olivers are always placing ahead of me with my ol B. Even if you just want to have fun I would definatly go with an Oliver. The only advantage I see is being able to slowly ease in that hand clutch that can help you more than anything you can do to the motor.
what class?
01-20-2002 19:55:45
 Re: Re: What will i need to pull my tractor? in reply to JD, 01-20-2002 16:00:11
what weight class are u guys pullin in?
john
jOHN
01-20-2002 06:15:27
I pull my 47 B alot and I really hope you are a very good loser.I have a great time with it but Im in the 4500lbs class.With no extra weight me and tractor weigh about 4470lbs so I have to pull against my own oliver 70 and other oliver 88.Good luck you will need it.
ENJOY
01-19-2002 12:38:28
First get a set of rules for where your going to be pulling. Then raise your draw bar to 18" to 20" as allowed. The closer the hitch point (inside of clevis) is to the centerline of the axle (18" or 20" seems to be the going rules) the tractor will pull the front up less until you get used to carrying the front wheels and steering with the rear brakes. Gear choices, 1st or 2nd depending on how hard or soft the track is. Most everyone at the pulls will help you as much as they can. Don't forget your weights if you can available
P.S.
BE SAFE AND HAVE FUN, and think LITE WEIGHT for a JD 'B'
BUCKMASTER 700
01-19-2002 08:28:01
hey bring your J D "a"and you AC to the 5500#class and let a 700 CASE show you the end of the track i just had to through that in its all in the fun of pulling Bruce go to antiquetractorpulling .com there you will find alot of your rules it has alot of the basics
laipuller45
01-18-2002 23:19:35
should have used red, flambeau red that is, j/k.... glad to see your interest in this. all you need now is a clevis, but once you hook it, once is never enough... then build it just a little, then a little more, and a little more, and a little more. i would reccomend wheelie bars if you have no way of mounting front weights. BE SAFE and have funn.
shoe
01-18-2002 23:06:53
About all I ever need to pull my stock F30 is a clevis on the drawbar. Go have some fun, win or loose it's a ball just being a part of it. Good
Luck.
chad
01-18-2002 21:48:27
if your just goin for a good time bring your tractor' friends and go at it...a B is just that a B so enjoy it and have fun
yep
01-18-2002 19:59:11
A WC..... .....Just funning.
hahaha
01-18-2002 20:13:56
 Re: Re: What will i need to pull my tractor? in reply to yep, 01-18-2002 19:59:11
I'll whip a wc with my A in the 4500# class!!!
John Deere Puller
