done did it now,,,
ChadS
12-11-2004 05:08:29
Got all excited wentr and got the top grille for my 460,, now the sheet metal is alot better looking,, maybe it will rub off on the engine now,,,,, ,,,,, give it some inspiration to wanna run,,, LOL! Oh,,, just bought a 301+ engine yesterday for it.... Oh the possibilites,,, Just had to show it, one step closer,, to what? I dont know,,, LOL! Have a good day! Thanks for looking,, ChadS
Migraine
12-11-2004 08:14:16
 Re: done did it now,,, in reply to ChadS, 12-11-2004 05:08:29
Chads is that a lightweight frontend you made for the 460? What does the tractor weigh with driver? I pull 2 560 gas with trike fronts and my 460 diesel turbo at 5000 lbs w/driver, but would like the stability of a wide front when that thing starts to get squirely at full steam? Our club wants us to put wheelie bars on for next season plus some lightweight fenders so I'm gonna have to lose some weight somwhere. Migraine
ChadS
12-11-2004 09:54:01
 Re: done did it now,,, in reply to Migraine, 12-11-2004 08:14:16
Migraine,, send me an email,, I have some info on lightening the tractor to run by you. Thanks, ChadS
ChadS
12-11-2004 09:50:21
With me on it, 3680 bare, 190 lb driver. The front end is from a gravity wagon running gear, the steer axle. I narrowed it up by cutting off one side, and rewelding it back on. The front axle weighs bout 160, but thats the enitre front end,, frame mounts and all. The frame mount for the front end, has 1/4 thick tubing, and where it mounts to the frame, it has 1/2 in plate on both sides, and has 8 bolts to hold it in place on to the frame rails. It is welded solid to the frame, but the bolts will hold it better to the rails. I was thinking about how much weight the axle could hold, once fully secured on the frame rails,, well, how much does a smaller parker gravity wagon full of grain weigh? divide that by 2. On the scale the front axle weighs 1120 if that means anything to you,,, ChadS
ChadS
12-11-2004 05:09:59
third party image
Opps,, forgot the picture,,, ChadS
