Cubeking
12-12-2004 13:52:41
Re: hiesler head and manifold not impressed in reply to 36 A, 12-12-2004 12:32:39
All that the unstyled heisler does is bump your compression up a little bit. While the heisler is probably flowed a bit better than the stock flathead, the better flow is negligable due to the small engine size you have. We run heislers on our styled As, and have been more than happy with the results. We also are running quite a bit more cubes in these tractors, with larger bores, and the larger stroke that styleds have over unstyleds. For a stock unstyled, the horsepower you got is right in line, so its not like something isn't working. Besides, two cylinders will pull better than what the dyno shows, as a 40 horse deere should beat a 40 horse 4 or 6 cylinder 9 out of 10 times. A couple of things you can do relatively cheap for some extra power is first, swap the crank for a styled crank, as it will give you a 6.75 stroke (.25 more). While you have the tractor apart to swap cranks, a cam regrind will always help, especially in holding the rpms better. The cam may not give much more hp, the tractor will lug far better than before. Also, roller rockers can help, as well as carb work and a hotter mag. A few hundred bucks will make a world of difference with the crank and cam, and everything will still be stock in that you could work the tractor all day long with no ill effects.
