John deere A
A puller
12-18-2004 17:36:10
I am doing some work to my 36 A I am going to grind the cam redo the head (bigger valves etc.) and work over the carb and put in compression donuts what will I gain from all of this
jd b puller
12-19-2004 19:00:04
 Re: John deere A in reply to A puller, 12-18-2004 17:36:10
Like the Nut said earlier, if you don't increase the cubes, the bigger valve may end up hurting you (reduces the speed of the air coming into the cylinder - worse mixing and turbulance).
Probably the biggest questions are...
1. How much do you want to spend? (to pay $10 hook fee to win that $17 trophy)
2. What class do you want to pull in?
3. What is it that you really want out of the tractor?
JDGnut
12-18-2004 18:15:03
You probably wont gain much with the bigger valves in that low of a compression (and small cid) engine... and may even lose some on the bottem end.. You will gain a little compression with the donuts.. but you would be much happier with the just the high compression AL pistons... You could also use the mid series of A cranks and gain a little cid, and a little more compression.. This is all for a stock style tractor... Good Luck,
JDGnut
A puller
12-19-2004 05:09:45
 Re: John deere A in reply to JDGnut, 12-18-2004 18:15:03
will the Al pistons for a styled A work and what do you think they will gain me and who would be a good person to get them off of. and to put the styled crank in would I have to change anything else
JDGnut
12-20-2004 08:37:03
 Re: John deere A in reply to A puller, 12-19-2004 05:09:45
The late AL piston will work without any problems.. I would try Henrich Repair or Triple G for the pistons... If you get the the mid year crank it will just be: a take one out, install the other.. The late A crank will work, but you will have to change some stuff.. Easiest to just find the mid year crank.. After thinking about the valves.... I think the early A's had smaller valves... you could setup a little... if you are going to change a few things.. the Hiesler heads used 70G valves.. I wouldn't go bigger, unless you are going to stroke it.. Good Luck
JDGnut
A puller
12-20-2004 14:12:24
 Re: John deere A in reply to JDGnut, 12-20-2004 08:37:03
will the rods from the 36 bolt on to the newer crank all right
JDGnut
12-20-2004 18:28:19
 Re: John deere A in reply to A puller, 12-20-2004 14:12:24
Yes the old rods will work.. but I recommend find a set of inset rods from an A or 60... not sure how long the babbit will last at the increased compression... JDGnut
