Re: figuring compression ratio
OLD -JOE
12-18-2004 18:05:15
FIRST FIND THE SWEEP VOLUME
radius x radius x stroke x 3.1416=cu. in. x 16.3872= cc (OF ONE CYL)
THEN YOU WILL NEED TO KNOW how far down from the block deck is the flat of the piston ( not the dish or the dome)
radius x radius x distant down x 3.1416=cu. in. x 16.3872= cc
THEN YOU WILL NEED TO KNOW YOUR HEAD VOLUME ( you will need to have the head off then you can use a large syringe to fill the combustion chamber to find the cubic centimeters
THEN YOU WILL NEED TO KNOW YOUR HEAD GASKET VOLUME
radius x radius x thickness x 3.1416=cu. in. x 16.3872= cc THIS IS WHAT YOU NEED IF YOU HAVE A FLAT TOP PISTON ( if you have a dished piston you need the cc of the dish OR if you have a dome piston you need the cc of the dome. EXAMPLE #1 JD 70 gas stock 2.9375 x 2.9375 x 7.000= 60.40 x 3.1416= 189.76cu in x 16.3872= 3109cc
deck cc 215 head cc 285 gasket cc 24
piston dish cc 110
----- ----- ----- ----- ----- total 635
sweep cc 3109 plus 635 divided by 635 = 5.8960 to 1 comp ratio
EXAMPLE #2
IF YOU HAVE A FLAT TOP PISTON IT WOULD LOOK LIKE THIS deck cc 215 head cc 285 gasket cc 24
piston cc 0
----- ----- ----- ----- ----- total 524
sweep cc 3109 plus 524 divided by 524 = 6.9332 to 1 comp ratio
EXAMPLE #3
IF YOU HAVE A DOME PISTON IT WOULD LOOK LIKE THIS deck cc 215 head cc 285 gasket cc 24
piston DOME cc -110
----- ----- ----- ----- ----- total 414
sweep cc 3109 plus 414 divided by 414 = 8.5096 to 1 comp ratio
Hope this helps
