cam grinding information.
36 A
01-03-2005 19:31:18
36 A .o45 over cast with hiesler head and manifold ,stock carb,newer crank.looking at getting a cam ground. 1 should i use my 36 cam or get a different one. 2 What grind should i ask for i"d like more low end torque. 3 Do they regrind the cam or just square them up so they are the same. 4 What results will i see, dont want to go do all the work and not be happy. I ges what i need to know is it worth the work and is everybody happy with results. Thanks
Sweeper
01-05-2005 20:21:12
 Re: cam grinding information. in reply to 36 A, 01-03-2005 19:31:18
Call Big Sonny at Bullet Cams, 662-893-5670. He has a pulling tractor, so he can talk pulling cams with you.
jdth
01-04-2005 03:57:51
You may want to contact Berry Cam out of Lester Praire, MN. They did one for an A for me a couple of years ago. Very infornative, quick, and reasonable. Don't forget to sent you followers for resurfacing.
MAD DUC
01-04-2005 02:54:56
Sent mine to Robert"s Carb. Told him what I was doing with motor work and pulling, he suggested the "compition grind". Got my cam back within one week. Love it, lugs down with plenty of torque.
