Which Tire Size for 9000 lb. class, Air Pressure?
4010
01-05-2005 16:36:27
Just purchased a 4010 John Deere diesel for pulling only, will be running in the 100-150 hp range. Should I run an 18.4 x 38, or a 20.8 x 38? Will be running primarily 8000 & 9000 classes, but will be getting up to 10,000. And finally what air pressures are run in these weight classes? Thanks in advance.
buickanddeere
01-06-2005 20:49:24
 Re: Which Tire Size for 9000 lb. class, Air Press in reply to 4010, 01-05-2005 16:36:27
What kind of track surface and how is it maintained during pulls?
4010
01-07-2005 16:27:07
 Re: Which Tire Size for 9000 lb. class, Air Press in reply to buickanddeere, 01-06-2005 20:49:24
Mostly moist clay tracks with a good bite.
buickanddeere
01-07-2005 20:18:53
 Re: Which Tire Size for 9000 lb. class, Air Press in reply to 4010, 01-07-2005 16:27:07
Given two tires with the same size contact area. A looser track works better with a taller/narrower tire, so some say. Of course some pulls have been won on loose tracks with short wide tires..... ..... ....
1066
01-05-2005 21:01:17
20.8x34 or 23.1x34 if you have no tire size ristrictons. air press depends on brand of tire.
4010
01-06-2005 16:13:19
 Re: Which Tire Size for 9000 lb. class, Air Press in reply to 1066, 01-05-2005 21:01:17
Would like to run a 38" tire, not really interested in the 34" because the setup I have is for 38" rims. I will put a set of 16.9 x38" on for 6500#, but would like to know what would work best for 8000-9000 lb classes.
Redman
01-06-2005 19:28:59
 Re: Which Tire Size for 9000 lb. class, Air Press in reply to 4010, 01-06-2005 16:13:19
20.8,a good rule of thumb for pulling is approx 1.25 lbs air pressure for every 1000 lbs tractor weight.start with 10 psi for the 8000 class,might have to shave it a tad if you have enough wood to spin them.
