aluminum wheelie bars...Bad idea???
770
01-08-2005 17:51:52
You think aluminum wheelie bars are a safe bet???
Redman
01-09-2005 18:46:39
 Re: aluminum wheelie bars...Bad idea??? in reply to 770, 01-08-2005 17:51:52
suggestion,go with chromemoly 4130.
light weight and strong,tougher than stone underwear.
depending on what you are putting them on they are simple to make,first tubes strait out with a 90 degree bend.
then a plate welded on the bottom,butt another pipe to the first and run at an angle back to the ?-(we try to bolt them to axel housing).
2 short pipe to do diagonal braceing and you are done.
lift rear of tractor full of weights with 1 side to be sure they will hold.
nc jd guy
01-08-2005 18:44:19
Funny thing about aluminum...
1. It weighs 1/3 that of steel.
2. It is 1/3 as strong as steel.
My opinion, good for things in which you can utilize sectional characteristics, but for something like this, I think you could make it just as strong with steel for the same weight.
CASEPOWER
01-08-2005 20:14:26
 Re: aluminum wheelie bars...Bad idea??? in reply to nc jd guy, 01-08-2005 18:44:19
Very good point, but a well engineered aluminum truss can be stronger then a poorly engineered steel one, that weighs ten times as much. I have built aluminum wheelie bars and they work fine but need to be engineered and welded properly. My opinion of course.
