governor strap for jd a
1951G
01-30-2005 16:23:59
Does anyone know where I can get a governor strap or spring for an unstyled A? Wasn't sure if they're reproducing these since mine has too much flex in it so the governor isn't opening up as much as I'd like. I know I could reinforce it with 2 springs, but didn't want to do this since some pulls don't allow governor overrides. Thanks.
JDMARK
01-30-2005 16:34:51
 Re: governor strap for jd a in reply to 1951G, 01-30-2005 16:23:59
Take the governor spring (strap) and shorten it about a inch then redrill a new hole that makes it stiffer and you have a factory looking setup. Mark
1951G
02-03-2005 07:43:16
 Re: governor strap for jd a in reply to JDMARK, 01-30-2005 16:34:51
Thanks, I might try that.
