NEED ADVICE
BUCKMASTER
02-01-2005 17:13:59
can any one tell me is the intake and exhaust header denny sells any good and the weld on hubs are they any good or should i spend the extra 75$ and get the clamp ons this is all goin on a stock 52 super m and the front weight bracket is there any need to have one out there that far my tractor seams heavy up front what do you guys think about the lower front bolster with the 5 bolt patern i just dont wanta waste money
ChadS
02-02-2005 08:49:19
 Re: NEED ADVICE in reply to BUCKMASTER, 02-01-2005 17:13:59
The denny header is not a good idea for your engine setup. You are not trying to feed big cubes, at 3500 rpm, which then this intake may be benneficial. Seen one on one of his 306 motors, the stock manifold made more HP! Look for an LP manifold, or one of the new manifolds being made, (I cant remember what the name is)Too big of a manifold on relitively stock engines will loose too much vacuum, and drops HP and torque when you are trying to increase power, at the same rpm. Dont use a big venturi in the carb! like the ones from an 806,,, or any 6 cyl engine, the 6 cyl, breathes a lot differently than the 4 cyl. messes the carb adjustments up. ChadS
cshaffer
02-02-2005 05:25:17
I have a light front end with the small hubs for Farmall. email or call 585-335-9274, Charlie
AC
02-01-2005 18:32:11
you should check and see if your club will even let you run weld on hubs and a big weight bar and a "non factory" exhaust manifold first.....
