Trans and rear end flush
AC Orange
02-04-2005 08:27:09
What is the best way to clean up gears in the trans and rear end that has water and a lot of build up? What is the best way to flush it out?
Thanks
Mopower
02-04-2005 12:02:52
 Re: Trans and rear end flush in reply to AC Orange, 02-04-2005 08:27:09
ATF will lubricate and also has powerfull detergents. Drive it aound doing light jobs filled with ATF. That should help break things up some. I am using 1/2 ATF and 1/2 80W-90 to clean up my MM.
ChadS
02-04-2005 09:40:20
Ive used diesil fuel to flush and clean out trannys and final drives, works pretty well, ChadS
