need more info
BUCKMASTER
02-04-2005 18:22:35
can any one tell the weight of a 1952 super m front bolster. another thing is the rear wheels from the axles out how much can i lose . my tractor now weighs 5494 with me on it ive already took the hydrolic pump out what all can i do to get down on weight . how light can i get it thanks
fellow puller
02-05-2005 18:17:14
 Re: need more info in reply to BUCKMASTER, 02-04-2005 18:22:35
You can start by draining the rearend down to the point that there is justb enough oil there to bath the drive gears.If you choose 9 bolt wheels would cut down tremendously,you can also use weld on adapters and then cut the axle stubs off.Aluminum bolster and 4 or5 bolt wheels.try some of those ideas to start.
