psi
bfarmall
02-09-2005 05:33:52
How do you find the psi by used the compression ratio thanks
jd b puller
02-12-2005 15:00:58
 Re: psi in reply to bfarmall, 02-09-2005 05:33:52
1 atmosphere is 14.7 psi, so you would think that a 10:1 engine would show 147 psi. It seems, however that the compression gage thinks atmospheric pressure is about 20psi. So a 10:1 engine usually reads about 200psi. 8:1 -- 160psi. Talk to someone smarter than me, maybe they have a chart or a better explanation.
champspa
02-11-2005 14:28:15
compression is the volume of displacement compared to the volume of the combustion cavity that is the ratio .
Goldie
02-10-2005 21:19:22
An Ampmosher of presure is 14.7 psi so in theory a 10 to 1 cr should give you 147 psi. But valve timing and volumetric efficancy will make a differance. Hope this helps.
jmj
02-09-2005 06:00:34
the psi is dictated not only by static compression ratio(measured ratio), but by the valve timing. the later the intake valve closes
the less the psi will be. if the intake closes early the piston has more drive time to build up pressure.
