case 730/830
Brian Hoffman
02-22-2005 13:46:30
Can someone help me with the HP and weight of a case 730 N/F gas and a Case 830 N/F gas Caseomatic. Would either of these be a good tractor to start stock antique pulling with. Thanks for the help.
jeffw
02-22-2005 16:28:16
 Re: case 730/830 in reply to Brian Hoffman, 02-22-2005 13:46:30
if there old enough there between 60-70 hp ipull a case 800 gas caseomatic does very well
Jaker
02-22-2005 16:35:19
 Re: case 730/830 in reply to jeffw, 02-22-2005 16:28:16
Hello Jeff,
What classes do you pull the 800 in? Are you completely stock? How do you do? I am thinking of building a puller and it will definitly be a case. If you would like to offer me some secrets it would be much appreciated. My e-mail is open. Thanks
jeffw
02-23-2005 06:56:27
 Re: case 730/830 in reply to Jaker, 02-22-2005 16:35:19
last year i puled my 800 completely stock with the exception of 10% over rpms in 7000 3rd gear,8000 2nd gear,90001st or 2nd depending did better in 8 and 9 but my 800 ended up 3 out of 23 at one pull in 7000 and ive beat several jd r's in 8 and 9 so all in all completely stock im happy. this year we got lp heads and 16.9 38s so look out jeff
