pertronix electronic ignition
brad thomas
02-27-2005 13:53:44
got a 56 model jd 50 with distributor number 1111558 with a positive ground. the pertronix kit shows this to fit a negative ground system for this distributor number. what do i have to do to make it work. thanks
Mike Aylward
02-27-2005 16:34:41
 Re: pertronix electronic ignition in reply to brad thomas, 02-27-2005 13:53:44
Brad, it is no problem to change your tractor to negative ground. Besides the obvious battery cable switch you reverse the wires on your ammeter, reverse the wires on the coil, and polarize your generator. I did this on my 60 puller and it works fine and has for years. Hope this helps. Mike
GRDINMD
02-27-2005 14:30:35
They make one for the negative ground too, it would be easier to find that kit, than change your system to negative ground.
