Oliver 88 Hi-Torque Starter
88Power
03-07-2005 04:31:27
Gents,
I need help locating a hi-torque starter for a large cube/hi comp 88 motor. I've heard that a Deutz or a Ford Diesel truck starter is used. Model or part numbers would be appreciated. Thanks.
buickanddeere
03-08-2005 21:37:50
 Re: Oliver 88 Hi-Torque Starter in reply to 88Power, 03-07-2005 04:31:27
24V on the stock 12V starter.
stroker 88
03-08-2005 17:41:16
we always used the 88 diesel starter. worked good. make sure you got good battery and heavy cables.
puller 2
03-07-2005 06:25:39
best you can do is a new John Deere replacement starter for 4020 they bolt right up and are available at any dealership for about $320.
Cody
03-07-2005 20:25:29
 Re: Oliver 88 Hi-Torque Starter in reply to puller 2, 03-07-2005 06:25:39
Get a Delco 28MT and buy a new bendix for it that will work with you flywheel. Lightweight and will start the biggest engines with a good batt. If you can't find one, email me I have a spare on my shelf.
torquenut
03-08-2005 04:24:25
 Re: Oliver 88 Hi-Torque Starter in reply to Cody, 03-07-2005 20:25:29
Cody, I know in the past you had mentioned a Ford 6.9 starter. Is this correct? a direct bolt up? What about the bendix for it?
Cody
03-08-2005 18:16:56
 Re: Oliver 88 Hi-Torque Starter in reply to torquenut, 03-08-2005 04:24:25
As long it is a 28MT. On some of the 6.9 starters, the selinoid is in the wrong place. It will bolt up but the selinoid will hang outside of the frame. The 4020 replacements are 28MT's.
