IH 6 cyl block bore.
ChadS
03-12-2005 08:05:20
Im gonna bore the block on my 460H later this month, How big can the 6 cyl block go and still run on the block without aftermarket sleeves? Id hard block it if I had to, Im looking at 366 Chevy big block pistons which are 3.937 bore. can the block take it? Im not stroking it, since I have a high compression cyl head, and on a budget. The block I have is a sleeveless combine block (C263) it is roughly a 69 or a 70 model year block if that means anything. any info would be great! Thanks! ChadS
jthh
03-12-2005 20:51:01
 Re: IH 6 cyl block bore. in reply to ChadS, 03-12-2005 08:05:20
a 301 block can be bored to 4" the sleeve less 263 are supost to be the same. but i know a few people that worked for IH they said most all the combine blocks were rejects the wouldn,t make the grade for a farm tractor, and i've sonic tested 2 sleeveless 263 blocks they were like .400 on one side the cylinder and .100 or less on the other
ChadS
03-13-2005 06:59:31
 Re: IH 6 cyl block bore. in reply to jthh, 03-12-2005 20:51:01
Yikes! Looks like Ill go with the .060 over 301 pistons, keep it a bit more solid. I was looking at the chevy pistons cause of the price of what I could buy chevy pistons VS the IH set. Im not trying to go too radical with the engine, want it to last for a long long time. Maybe some day,, put it in a real 460??? The hunt is on for a set of LP, High Alt, .060 over 806 pistons! Hope there is some left out there somewhere! Thanks guys! ChadS
eric stephen
03-13-2005 07:21:44
 Re: IH 6 cyl block bore. in reply to ChadS, 03-13-2005 06:59:31
Hey chad s i have a set of ih 301, .045 os hi-compression pistons, that i would consider selling, e-mail back if interested. thanks eric stephen
mjs in mo
03-13-2005 18:18:53
 Re: IH 6 cyl block bore. in reply to eric stephen, 03-13-2005 07:21:44
eric if you sell your pistons how are you going to build that 460
eric stephen
03-13-2005 18:55:40
 Re: IH 6 cyl block bore. in reply to mjs in mo, 03-13-2005 18:18:53
i think i am going another route with the tractor.
ChadS
03-13-2005 08:21:52
Im interested! I want to get er done! Soon as the 450 project gets out of the shop, the 460 is comming in. So much fun, so little time! ChadS
AC
03-12-2005 14:42:21
I got a good 263 assembly if you need one.....
Earl S.
03-12-2005 09:56:23
We used to bore the 560 gas for M&W pistons&dry sleeves. The bore was 3.750 but I looked in my old M&W book it didn't give spec on the sleeve. Sometimes we would bore through and have to install a dry sleeve first then bore and install the thin wall flanged M&W sleeve.I think the 706 gas had a little more meat. I don't recall boring through on them. Earl
