John Deere A 6-2 Powerblock Bore
A-Man
03-13-2005 15:22:25
How much can you bore a 6-2 powerblock without having to hardblock or anything like that.
a puler
03-13-2005 20:44:39
 Re: John Deere A 6-2 Powerblock Bore in reply to A-Man, 03-13-2005 15:22:25
we have one with a 6.125" bore + .045 because they are .045 over aluminum John Deere G pistons turned down. the sleeves get real thin if you go much over that. I would think you could put a .090 G piston in one, but if you want any kind of compression, i would resleeve it if you want to go bigger. I have heard of an A with a 6.75" bores....I don't believe they can run water, but a huge bore like that is possible. If i had to do it over again, i would spend my money on a used set of 5.75" cat pistons because the $450 for new G pistons and $500 or more for a powerblock...and then the cost to bore it..., its cheaper to buy a set of used or new 5.75" bore cat pistons and bore the stock block... just my 2 cents..... .
o,kspuller
03-13-2005 20:35:06
You can bore it 125 over or have the sleves taken out and go 6.500 with the sleves welded in your block,If you need info on the block ask shawn from neb , or dave from lovland shawns old A it has 6.500 in it,
2 Cylinder
03-13-2005 16:59:51
I bored mine .125 over without any problems with leakage. I've heard of people rolling the dice and going for more than that.
Mike n Mo
03-13-2005 16:38:50
The common overbore is .125". 3/16 overbore is probably getting kinda iffy. My $.02. Mike
Mike n Mo
03-13-2005 16:38:35
Mike n Mo
03-13-2005 16:38:13
A B G
03-13-2005 19:10:19
 Re: John Deere A 6-2 Powerblock Bore in reply to Mike n Mo, 03-13-2005 16:38:13
JUST did one 125 over had no problme can go more didnt need it got a G with hardblock in it and it sucks gets hot fast
Jeremy Brault
03-20-2005 18:12:21
 Re: John Deere A 6-2 Powerblock Bore in reply to A B G , 03-13-2005 19:10:19
Doing mine right now with 6.25 hopefully no problems, new sleeves too. Any help for me would be great too
Jeremy
