Tire Pressures WD 45
A C Orange
03-13-2005 16:35:36
What would be a good starting tire pressure on a WD45 Allis in the 4000, 4500 Lbs. classes,soft and hard tracks? Thanks
wdpuller
03-15-2005 11:40:13
 Re: Tire Pressures WD 45 in reply to A C Orange, 03-13-2005 16:35:36
i keep mine around 9 to 11 lb for 16-9 26
redcub
03-15-2005 20:25:16
 Re: Tire Pressures WD 45 in reply to wdpuller, 03-15-2005 11:40:13
Are you running pressed steel off a combine?
A C Orange
03-16-2005 12:31:11
 Re: Tire Pressures WD 45 in reply to redcub, 03-15-2005 20:25:16
No, I'm running the standard spin out wheels.They have 14.9x 28 tires on them.
AO
03-14-2005 04:28:03
I have learned to adjust to different conditions at almost every pull. I have been as low as 4 psi up to 10 psi. I run 13.6 28's at present.
