shilo ohio pull 2005
820puller
03-20-2005 17:51:11
any pull dates an a contact phone ##. thanks
Z-Puller
03-21-2005 16:25:36
 Re: shilo ohio pull 2005 in reply to 820puller, 03-20-2005 17:51:11
I found two shilo ohio were is the pull located by.
820puller
03-21-2005 17:12:38
 Re: shilo ohio pull 2005 in reply to Z-Puller, 03-21-2005 16:25:36
its by plymouth ohio-not to far from mansfield. on 603 i believe
firefarm
03-20-2005 18:52:32
 Shiloh, Ohio 2005 in reply to 820puller, 03-20-2005 17:51:11
The pull will be on July 30 starting at 10:00 a.m. We are going back to using Currens sled again. Classes and rules the same as in the past... Stock (no cut tires, 3.5 mph), Mod stock (no cut tires, 4.5 mph), Open (cut tires, no speed limit). Weight classes 3700, 4500, 5500, 6500, 7500... Weight classes are open for change if there are enough tractors to pull in class. 75% payback with some added purse thown in.
Call 419-342-2670 for more info
Jason Snyder
