JD 720LP. Cut head 50 thousands
Ben.So.Tex
04-18-2005 18:53:46
I had the head reworked, grind vavles, And the had the head plain, and cut 50 thousands off the head. Now while installing the pistons I notice that the piston comes all the way to the top.. Did I mess up by taking off the 50 thousands off the head?
buickanddeere
04-19-2005 05:16:21
 Re: JD 720LP. Cut head 50 thousands in reply to Ben.So.Tex, 04-18-2005 18:53:46
With the mild valve timing, chnaces of whacking a valve agaist a piston is nil with just a 50 thou cut. What is the deck height with those LP pistons ?
Ben.So.Tex
04-19-2005 09:02:36
 Re: JD 720LP. Cut head 50 thousands in reply to buickanddeere, 04-19-2005 05:16:21
I check the head and piston and it should clear by about 1/2 inch. I didnot have the head at home yesterday, But when I saw the raised portion of the piston sticking out of the block it look bad, The raised portion sticks out about 3/8 inch and the well in the head at the shallow end is 1 1/8 inch.Thanks Ben
