Vinson manifolds for IH
ChadS
04-21-2005 11:19:29
Anyone ever used a Vinson manifold on a stroker engine on an M-450? My next engine Im building has a 321 cube engine, and round 245 psi of compression. The Vinson looks better than a stocker intake, but,, the 450 that we just finished up, ran a stock 450 intake, acted as if it needed a bit more air above the carb. Lots of manifold vacuum,,,,, Id bet this engine will need a big intake this time round, small cubes, high compression, volumetric efficency if you can relate,,, seems to have been improved greatly,,, but, my opinion is that it is a whole lot more than what I expected. Just thinking out loud,,,,, ,, trying to make it breathe. Chad
Flogger
04-22-2005 07:43:06
 Re: Vinson manifolds for IH in reply to ChadS, 04-21-2005 11:19:29
Seems like the 400-450 gas and LP manifolds are the hot ticket. I guess the downside to the vinson is that it's heated. Probably not too big a difference powerwise. One thing I like about the Hank Steel manifold is the 3 inch exhaust outlet. I've seen a few 400-450s with the stock pipe/flange cut out and a 3 incher welded in.
REDEYE
04-22-2005 10:24:01
 Re: Vinson manifolds for IH in reply to Flogger, 04-22-2005 07:43:06
what is a Vinson and a Hank steel manifold? pictures? Who sells them? only "better" manifold i ever heard of is the lp, what are these manifolds?
thanks
Flogger
04-22-2005 11:16:08
 Re: Vinson manifolds for IH in reply to REDEYE, 04-22-2005 10:24:01
The Vinson is a replacement stock gasoline manifold. I'ts the one folks like oem, bates, steelwheel ranch, etc all sell as a replacement for the M-450 tractors. The intake is heated by the exhaust so it's really not a performance minded manifold. The Hank Steel is a repo of the Johnson LP manifold and supposedly a good one. Haven't seen one on a tractor yet though.
Flogger
04-22-2005 08:52:29
Mine's running good. Didn't have to do anything to the motor over the winter... for a change, lol. Making some longer weight racks in hopes of hooking it to the ground a little better. Looking forward to blowing the cobwebs out of it in a week or 2.
ChadS
04-22-2005 07:53:52
Yeah, the Vinson does look like the old kerosine manifolds. Small pipe too. The intake runners do look bigger VS a stocker SM-450 manifold, but I dont know,, heated manifold,,,, I bet that would not help much for power, cause cold air makes power, heat makes????? ?? LOL! How's your project comming along? Chad
ChadS
04-23-2005 08:16:23
 Re: Vinson manifolds for IH in reply to CLARENCE BARENIE, 04-23-2005 08:09:57
LMAO!!! Well here at the tractor shop, we'll test em, will sink em if they dont swim. I got a vinson manifold for an H-350, and thats a nice intake! Yeah, Ive found a LP manifold, going to copmare the two anyhow,,, found it cheap,,,, I have to go pick it up. SM is comming along,, rods are done, just got the pistons in for it, time to make the donuts! LMAO! Have a good day sir! ChadS
B BARENIE
04-26-2005 15:25:28
 Re: Vinson manifolds for IH in reply to ChadS, 04-23-2005 08:16:23
I GOT NO IDEAR WHERE YOUR MAKING ALL THESE TRACTOR PART'S AND ENTIRE TRACTOR FIND'S, BUT IT AIN'T IN THE JUNK YARDS I'M LOOKING IN !
MUST BE SOMETHING WRONG IN THE WATER BETWEEN HERE AND INDY !
I BETTER START MAKING THE ROUND'S ON DIFFERENT HIWAYS, THAN I'M TRAVELIN !
yOUR STILL A .25 INCH SHORT OR A FULL BLOWN TRACTOR BUILD-OFF !
HAVE A GOOD EVENING !
clarence barenie
04-21-2005 19:54:18
if you could run an after market manifold, like everyone else in America does, your best bet would be to call hank steel ! Resides in michigan. He offer's a very nice johnson propane manifold. Maybe inlarge the venturi i.d. by 125thds.
Or take the 450 manifold poor it full of battery acid an let it cook for about a week ! Also you could actually have a cam grind done ! might cost a few buck's , but might fix a bunch of other problem's, maybe after a cam grind, an offset keyway !
ChadS
04-21-2005 20:35:24
 Re: Vinson manifolds for IH in reply to clarence barenie, 04-21-2005 19:54:18
Bud, If everyone followed everyone else, we all should build identical tractors. I do with what I have in front of me, and if I have the Hank Steel manifold, and wanna spend that kind of $$ on it,, Id say who do I make out the check to? But,, I dont. I do, with what I choose. The 450 had the biggest carb allowed in the rules. Ill work to make things right, not spend a dollar for something that someone else has. The cam in the 450 is fine, I told you, and every one else, the science is already there, just have to be put to the test. and testing is still an everyday thing!!!!! I stopped on the 450 cause with what was there,, it did do better! it was as good as it gets. and for what it is,, even you,, can say,, thats impressive. Im not going to spend $$ on parts, that I dont know for sure will work! Thats what Dennys carb shop is for!!!! That 450 will be fine,, but can be better, after thinking about this pullers style, HP was plenty for what he needed. This SM,, will be all out, as much HP as it can get, with what is there. Thats why I asked about the Vinson manifold. The origianl SM manifold, will not git r done this time round, that,,, I know for sure! ChadS
clarence barenie
04-22-2005 04:14:35
 Re: Vinson manifolds for IH in reply to ChadS, 04-21-2005 20:35:24
ok !
After hearing a big cube (m) crank over with an 8060d head on it, I learned a few things !
1) using stock rods in a small stroker, increases piston speed, (rpm's being the same ! Internally the barrel fill becomes more efficient, leaving the valve train the same, while adding more cubes, creates a new problem !
2) higher compression (`more h.p.) also puts more load on an ineffective valve train !
3) head work, and valve work becomes extremely important !
On these 450 gas heads, with bigger cubes, I would and will definitely unshroud those valves, that air has got to get in and out !
A cam grind is manditory, because vacuum has increase enough to run a bigger cam, valve open father, less vacuum. more efficient fill in same time frame, (more cubes to pull it)
Eliminating the valve guide protruding into the intake runner's also has to add greatly, to eliminating deflection and turblance !
This time , maximium h.p. will be asmuch about air flow, as cubic inch !
chad, sooner or later, I'll draw a line and finish my project, but this learning process just added huge valur this week alone !
have a good day
enjoy he buildup
bud barenie
ChadS
04-22-2005 07:44:47
 Re: Vinson manifolds for IH in reply to clarence barenie, 04-22-2005 04:14:35
Im hearing ya! Ok, let me see if I can get scientific here too. LOL! First off, you ever hear a H with a 8043DD head with 300 psi of compression crank over? I bet I go through 2 or 3 starters a year cause it cranks so hard! Ive busted the starter clean off the housing before! I broke down, and built a starter for the H, started from brand new, and now days,, when I hear the starter act sluggish, that tells me Ive burned up the brushes in the starter. Replace em, and it wil crank it like a stocker with a 1000cc battery. Now, on the 450,, had to replace the starter, cause the old one was junk, but thats a different story,,, Id say that what I did when I built the engine, I did in fact increase volumetric effeciency, more air thru the carb, (biggest venturi available) More through the intake manifold, (did nothing about that) More air thru the head ports on the intake side, (stock ports not polished) Thru the valves, (stock valve train) and more air into the chamber, (added high compression pistons, and a small stroker). With all that, I increased efficiency thru the intake side of the engine. granted, the stock 450 manifold will not flow enough air to feed this engine much above 10% over rpms. and its only 307 cubes, at 210-215 psi of compression! Stock was 281 and 125 psi! went from 58 hp up to 85+ 28 cubic inch increase now,,,, and picked up 90 psi of compression. Id go out on a limb, and say, the volumetric efficency for 307 cubes for the stats is border line radical. Vacuum levels, are very very high in the manifold, which in most cases in farmall engines, its the total opposite, low manifold pressure, but its got the biggest carb and intake to run it. Therefore decreasing efficeincy. cause the engine cant draw it through. Not enough static compression to properly take advantage of the new intake and carb is designed for. In the engines I build, its back to properly setting up the induction system to take advantage of the efficiency increase, which usually means big venturis, and big intakes, port and polish work. Id say no cam changes, simply because the air that is present, can be made to flow more smoothly by port and polish work, and bigger intakes, and carbs. All you have to do is make room for the extra air/fuel charge. Now, it stops at the intake valve when its in stock form, but,, in order to know if the valves have to be enlarged, or unshouded, or what have ya,, is if, when on the dyno, you have a characteristic, that cant be changed by making other adjustment to compensate. say like you have it at 540, run it, shut it down, and even though it smokes out the pipe, the plugs are white as snow. you can jet it jet it and rejet it again, and still no change in the plug color. That tells me that a limit has been reached for the limited intake, and head ports and valves, increase in size will help the efficiency. you mite pick up some HP, but not much. 5-6 hp if that,,,, but, afterwards, you have an engine that can utilize all the potential created from a high compression, high effieciency engine. Limitations my friend, you can only go so far, with what is there, and when more is needed, 2 choices, A: do it yourself and git r done, or B: buy the expencive parts, which may not be legal to pull due to the part numbers,,, but its only $$$$$!!!!! !!!!! Not my $$ so I will take plan A. ChadS
CLARENCE BARENIE
04-24-2005 13:13:57
 Re: Vinson manifolds for IH in reply to ChadS, 04-22-2005 07:44:47
I DISAGREE WITH THE MANIFOLD STUFF, SEEN TOOMANY STROKERS PULLING IN OUR MODIFIED DIVISION TO ASSUME THE 450 MANIFOLD, WOULD NOT BE CAPABLE OF FEEDING UPTO 450 CUBES !
IF YOU COMPARE THE INTAKE VALVE TO THE I.D. OF THE INTAKE RUNNER, THEIR IS A HUGE DIFFERENCE , IF YOU PUT A SET OF INCREASE RATIO ROCKERS, ON THAT PUPPY FOR APROX 250BUCK, DIVIDE THAT INTO, SAY A 5-6HP GAIN THATS ONLY 50 BUCKS A HP, MIGHT BE CHEAP IN COMPARISON, TO A BURNED PISTON, i'M NOT UNDERSTANDING THIS WHITE PLUG!
THAT'S EITHER TO LITTLE FUEL MIX AT THE CARB, OR POSSIBLY TO HOT A PLUG ! WHICH IS RUNNING UP TEMPATURES IN THE COMBUSTION CHAMBER !
THAT 450 MANIFOLD IS FINE.
THEIR DEFINITELY IS A CORRECT RATIO FOR FLOW THRU THE INTAKE VALVE, THE 450 MANIFOLD WILL FROST UP WITH EVEN A PORE 281 CI (M)
WHAT IS STOCK MANIFOLD PRESSURE ON A 450 AND WHERE ARE YOU AT ! 4130 PLUG, HOW DOES THAT COMPARE TO A C81 AUTOLITE !
OKAY THAT'S ENOUGH FOR NOW !
